[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 696: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4776: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4778: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4779: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4780: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3897)
NordicR • View topic - Nicklas V70R Saffran
Beskriv din bil eller projekt med text, bilder eller varför inte en video
Moderator: Moderator Gruppen
Re: Nicklas V70R Saffran
Postby rockabillyrebel » Tue 26 Jun 2018, 22:09
Bilen ser grym ut! Bakhjulslut är inte bara roligt att köra med, det ser riktigt bra ut också :P
rockabillyrebel
Nordic R - Medlem 2018
Landskap:
Namn:
Nordic R -: 610
Fordon::
Postby Martin Lund » Tue 26 Jun 2018, 23:04
Martin Lund
Nordic R - Styrelsesuppleant
Landskap:
Namn:
Nordic R -: 122
Fordon::
Postby Schmidt » Sat 30 Jun 2018, 21:26
Schmidt
Landskap:
Namn:
Nordic R -: 435
Fordon::
Postby Schmidt » Tue 03 Jul 2018, 19:43
Beställde en helt ny gasspjällsgivare, då jag tycker att den inte går ner i varv så snabbt som den borde
Har bytat den och får se hur det blir nästa gång jag kör :)Image
Skickat från min ONEPLUS A5000 via Tapatalk
Schmidt
Landskap:
Namn:
Nordic R -: 435
Fordon::
Postby Schmidt » Mon 30 Jul 2018, 18:50
Har idag varit ute och kört
Bilen gick tyvärr sämre med ny tps från bildelar24 :(
Så jag bytade tillbaka och den går riktigt fint nu :)
Nu blir det lite små lull innan Volvoträffen i Bromölla i helgenImage
Schmidt
Landskap:
Namn:
Nordic R -: 435
Fordon::
Postby Schmidt » Sun 05 Aug 2018, 18:59
Bilder från lördagens utflykt :D
Nu taggar vi inför Vallåkra :dance:
Schmidt
Landskap:
Namn:
Nordic R -: 435
Fordon::
Postby Schmidt » Mon 20 Aug 2018, 21:48
Så nu har även Vallåkraträffen passerat :shock:
Påväg till träffen så flög min ena taklist av och när jag kom fram så fanns det fett på fälgen.
Troligtvis var det från drivaxeln och idag hissade jag upp bilen och visst var det drivaxeln.
Trodde först det var hål i damasken men det visade sig att klammern hade lossnat.
Så nu funderar jag på att köpa en helt ny Volvo original :think:
Sen så har takluckan lyfts i framkant och vill inte gå ner, men det ska inte vara så svårt att justera sa Alp och Öberg så får tro på dom :whistle:
Här kommer enda bilden från träffen
Schmidt
Landskap:
Namn:
Nordic R -: 435
Fordon::
Postby Martin Lund » Mon 20 Aug 2018, 21:58
Du är inte den först som tappar en taklist.
Jag hade en som flög av efter Östgötarundan för något år sedan ;)
Den lossnade vid ca 240-250km/h fast han stanna och plocka av den sen vart det "bara" att böja tillbaka den och fästa runt rutan igen.
Hade du dubbel så många clips på de släta listerna som det "krävs" för att dessa ska sitta ordentligt? Än vad de med Rails kräver.
Surt med kladdet med drivaxel. Men enkelt fixat om än riktigt tråkigt att få bort.
Att justera takluckan är inte så svårt.
Tilta upp den.
Dra bort plastskydden i sidorna rakt bak. Då kommer det fram 3? st skruvar på vadera sida. Två av dessa är för justering av luckan en för fram och bakkant av luckan. Lossa den främre skruven lite på varje sida och tryck ner takluckan lite. SKruva åt och kontrollera så att du kan öppna stänga ett par gånger. Evt kan du få justera lite på den bakre skruven för att takluckan ska ligga jämt med taket. Men det är riktigt enkelt. Sen är det bara att trycka dit plastskitten i omvänd ordning som du lossade de i.
Ska man ha av takluckan (glaset) så lossar man dessa skruven och sedan drar baktakluckan när man har den tiltad. DÄr efter kan man "tilta ner " tak luckan och dra fram solskyddet för att trycka in fjädern som håller solskyddet på plats och dra fram för att trycka in det andra paret fjädrar och då kan man lyfta ur solskyddet för att tex rengöra tyget eller att limma om det om det har släppt vilket är ganska vanligt förekommande.
Martin Lund
Landskap:
Namn:
Nordic R -: 122
Fordon::
Previous
Return to Våra bilar
Who is online
Users browsing this forum: Google [Bot] and 0 guests
cron
